1984 LT125 Timing?
Old Jul 2, 2001 | 07:18 PM
regal007's Avatar
Anyone know what the timing should be set at on a 1984 LT125? It ran OK last summer this summer it won't start. It has good spark and is getting gas.
Old Aug 3, 2005 | 12:16 AM
izzy3338's Avatar
Default 1984 LT125 Timing?
first take off the chain tensioner, then look at the end of the cam, there should be two lines. these two lines should be horizontal the the top of the cylinder head (keep in mind that the gold pin on the end of the cam should be on the top). once this is lined up look for a small t on the flywheel, while holding the cam in place, rotate the flywheel to the left until the t matches up with the pointer on the tranny case. hold both in place and install the chain tensioner.
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
timster911
Jul 13, 2015 01:57 PM
