Help (Tires)
Old Sep 30, 2001 | 01:03 AM
02Raptor's Avatar
I need help with a Pair of Tires. Well I took off spyder track tires and Had to use a Bead Breaker well I only have one set of rims. Now I want to Put on a Pair of Turf Tamers and I cant get the Tire on the seal On one side. So what do I need to Do? Do I need any Special Tools?
Thanks,
Andrew
Old Sep 30, 2001 | 12:20 PM
DannoLT250R's Avatar
I have a set of turf tammers on my ugly gold factory wheels. To seat the beads, I wrapped a tie down around the tire, pulled the valve out of the valvestem, and put some goop hand cleaner around both beads on the tire(the goop was close, any dish soap should work), then air it up. The soap will help the bead to slip into place and the tie down will keep the tire from expanding in diamiter and force the side walls to expand pushing the beads into place. Try this, I works for me, I have mounted several tires doing it this way.
Danno
Old Sep 30, 2001 | 08:53 PM
stormnorm's Avatar
spray some quik start for diesel engines inside the tire then light a match and THROW IT IN KABOOM instant bead seal. BE VERY CARFUL spray only a small amount in there and if possible try to throw some sparks in there using a grinder and a piece of steel...reason being you don't want to be too close to this tire when it pops
p.s. not responsible for any injuries that you may sufer
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
