Quadzilla probs.
Old Oct 6, 2001 | 08:51 PM
BomBanshee's Avatar
Well i was going to go riding today and got on my zilla and it was very had to start and I just put in a brand new plug today when it finally started, after i was worn out from kicking, it would only run on full choke this usually means it is not getting the right amount of fuel but the fuel was on and its getting to the carb ok and i just put a full tank of fuel in it. So now any help you could provide is very very appreciated. [img]i/expressions/face-icon-small-sad.gif[/img] And now it wont even start at all.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 6, 2001 | 11:35 PM
BomBanshee's Avatar
Bump ! ! ! !Please I nreally need some help.
Old Oct 7, 2001 | 09:16 PM
LT5001987's Avatar
Bombanshee
I hope you just don't assume that the quad will always run right with a new spark plug. Did you...
-clean your air filter
-check float height
-check that the float is not stuck in the wrong position
-change your fuel filter (if you even have one)
-check that fuel is actually making it out of the petcock
-unclog your pilot jet
I can go on and on. Take your carb apart, clean it, and put it back together again. If it ran before today and suddenly it is not running, then you've got some funny business going on.
Old Oct 7, 2001 | 11:05 PM
BomBanshee's Avatar
Well I got it running again it was the float it was stuck open and was flooding out, but no I dont think it will run good with a new plug I only replaced it because the other one was junk and new someone would probably say change the plug, but thanks anyway. [img]i/expressions/face-icon-small-happy.gif[/img]
Ashley S
Feb 18, 2024 08:56 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ashley S
Aug 6, 2015 12:56 PM
FENDERBENDER
Mar 12, 2000 01:04 PM
