89 lt250r
Old Oct 13, 2001 | 12:34 PM
suzukiboom's Avatar
I just rebuilt my 89 lt250r i put a pro design coolhead on,re-sleved it back to stock a wiesco piston and almost everything you could think of,but i still have the stock carb on it and in all the gears, in the mid to higher rpm's it bogs and spudders like crazy i know that i have to rejet the carb but should i go bigger or smaller on the jetting,is it running to rich or to lean,any help would usefull
Old Oct 13, 2001 | 07:33 PM
2strokesrule's Avatar
I went to hell and back with my stock Mikuni, I finally smartened up and bought a Keihin Air Styrker 35 for $150.00, best money I ever spent. I must have dropped $30.00 in main, pilot jets and needles, but the thing always had problems somewhere. I got the AirStryker, installed it, did a plug check, looked good, and I have not touched it since.
Old Oct 14, 2001 | 05:43 PM
Kadafiy's Avatar
Get the air striker carb it makes a hell of difference. I went with a 38 for my modified lt. Test your compression to see what size you need. You won't regret it.
Old Oct 15, 2001 | 02:59 AM
BomBanshee's Avatar
Hey 2strokesrule can I get a Keihin Air Stryker for a Zilla if so can you direct me to a site to order it. Thanks.
Old Oct 15, 2001 | 08:54 AM
http://www.hy-tech-atv.com/html/Order%20Page.html
This place HY-Tech has the lowest prices I have seen.
you will have to call them as I do not see and carbs on their web site but their prices are as follows.
Keihin PWK 38 AirStryker $169.00
Keihin PWK 39 $169.00
I have and AirStryker on my 250 and it is great, But for your 500 you should probably go with the PWK 39
Old Oct 15, 2001 | 07:36 PM
Kadafiy's Avatar
I bought my Air striker carb from Hy-tech also. Nobody could even match their prices. Their # is (909) 794-5776
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
