Carb setup
Old Oct 20, 2001 | 11:32 AM
Kadafiy's Avatar
I put a 38 air striker carb on my lt250r and the boot attaching the carb and airbox was too small so I shaved the inside of it. This did the trick but it does not fit very securely and is a pain to put on the carb. I was wondering if I could use the boot from a quadzilla? They have a bend in them but I don't know if it will bend around my shock like the stock boot. Has anyone did this or modified their own if some way? Any help is appreciated. Thanks.
Old Oct 20, 2001 | 12:45 PM
2strokesrule's Avatar
I did the same as you, I genlty sanded the inside of the carb boot (on the reed side) and mine did seem to fit good. I have an 87 cylinder on my 92 QR250, so I didn't have a choice but if you have and 88 - 92 cylinder you can buy a Boysen rad valve, that comes with a proper boot. This would be a good investment for you as the 88 - 92 reed cage is very small and bairly flows enough air from the stock carb never mind 4 mm more.
Old Oct 20, 2001 | 12:54 PM
Kadafiy's Avatar
I have a '91 lt and I already have the Boysen rad valve and reeds. The boot that I can't get to fit right is the one that connects the carb to the airbox.
Old Oct 21, 2001 | 02:31 AM
ProtegeDK's Avatar
To get the boot from the air box on a bigger carb., just boil it. It will stretch and be easier to get on, it will hold that shape also. That is how i got a 39mm PWK on my 90lt250r. I had to sand the carb to reed boot.
Old Oct 22, 2001 | 04:20 PM
VegasQuadracer's Avatar
Kadafiy,
I don't have any suggestions for your dilemma, but I was wondering if you could give some feedback when you get your carb installed. I've got an 89 LT250R and I wanted to try the same carb and Rad Valve but didn't know how much of a difference it would make over my stock Mikuni which is jetted to the max.
Anybody else have a suggestion for a carb/reed setup?
Old Oct 23, 2001 | 12:07 AM
Kadafiy's Avatar
I have already had the carb on the bike and running and it makes a big difference. I also jetted my carb out to the max before moving up to the 38. Make sure to check your compression to see what size carb is right for you. I put the boysen rad valve with carbon fiber reeds on a while ago and they really improved the low end. Now I'm making a reed spacer which should help too.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
cornermike
Jul 8, 2015 11:44 PM
