Quad idles inconsistently. ? for you carb experts
Old Jan 16, 2002 | 02:25 AM
nyroc's Avatar
a friend has an LT300,and another guy has an lt185, and these quads both idle inconsistently.
They have to keep adjusting the idle speed screw, the idle won't stay right.
It seems as though the pilot screw has to be turned out pretty far. I put a pilot jet 2 sizes richer in one of them, and it helped. Maybe I gotta go even more.
Does this problem ring a bell? Is there a seal that could be leaking. It seems like this happens to lots of old motorcycles.
Old Jan 16, 2002 | 08:34 AM
Defiant's Avatar
Is that the carb that has the primer pump on the side of it ? If it is the diaphram is got a hole in it and is leaking air and causing the erratic idle I fixed a LT125 that did that the part was 32 dollars and it idled fine after that.
Old Jan 16, 2002 | 09:07 AM
garyc660R's Avatar
I am by no means an "expert", but the first thing to do is dis-assemble the carb and clean it....especially take a close look at the idle circuit. Lots of gunk can build up in carbs over the years.
JBibb
Jul 4, 2015 10:16 AM
VRRRRT
Jun 27, 2015 09:38 AM
qingqi50
Jun 26, 2015 01:58 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
