WiLL this Work ???
Old Jan 23, 2002 | 07:33 PM
stutzdog's Avatar
I was looking at my SUZUKI LT-A500F and checking the CV joint rubber coverings for tears after an extended ride in the Arizona desert and was wondering if this little subject that I am about to bring up will work . What do you think about using a vary small lube needle with a zerk attachment on it and a grease gun filled up with some permimun molybdenum disulfide grease and inserting the needle into the rubber boot and pumping a nominal amount into the void created by the boot. After the needle was removed a little dab of silicone sealer could be placed on the puncture hole . This would sure be an easy way to lube the steel ***** and the bearing races on all the drive axles and possably displace what ever water was in there.....WHAT DO YOU THINK ??
Old Jan 23, 2002 | 10:55 PM
icav's Avatar
Go try it and find out if it worx i guess.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
