Bottom End Rebuild
Old Feb 27, 2002 | 01:18 AM
chuck1221's Avatar
I just recieved a new crankshaft and a main bearing and seal kit for my 91' suzuki lt250r. I was wondering if anyone had any tips on installing or removing old bearings or the old crankshaft. I know my manual says you need special tools, do you actually need these "special" tools? While I am replacing my main bearing I want to replace any other bearings in the crankcase that I can. What other bearings are there other than the counterbalacer?
Any tips or tricks on doing this would be very helpful.
thanks,
chuck
Old Feb 28, 2002 | 01:23 AM
Jason454's Avatar
Your old bearings should have stayed in your case halfs. I usually just tap them out with a brass punch. Then tap the new ones in with a huge socket. Put the crank in the freezer for the night. Pull it out and assembly when it is still very cold. Should slide right together.
Old Mar 1, 2002 | 12:00 AM
chuck1221's Avatar
Thanks for the help I will try it when I take it apart, hopefully I will do it within the next couple of weeks.
chuck
ReconBayou
Oct 31, 2022 05:37 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
