Is replacing a top end hard
Old Apr 10, 2002 | 06:04 PM
Scottytohotty's Avatar
I have an 86 230 Quadsport that I believe the top end is out. Are these pretty hard to work on? Has anyone out there rebuilt the top end of their 230 Quad? The shop wants around $500 to rebuild it. Any help would be grateful.
Old Apr 11, 2002 | 12:54 AM
1986SuZuKiQuAdRaCeR's Avatar
*spits coke out all over monitor at sight of price*
eh... What's wrong with the top end? Head damage? Cylinder damage?
I threw a new piston, rings, circlips, top con rod bearing, gaskets, wrist pin and took all the pieces of the old piston out of the head...
It was easy.
But, a four stroke is totally different and you didn't describe your situation good enough, so... I can't help you.
Old Apr 11, 2002 | 04:00 PM
95wolv's Avatar
Hi,
I'm currently in the process of rebuilding the top end on my 4 stroke, a 95 Wolverine,the only part to keep track of is making sure the cylinder is at TDC,and tie up the cam chain so it won't fall into the lower part.A shop manual for your machine is a must,your will need it for disassembly and reassembly directions,special parts to watch for,and torque specs on all the fasteners. It's not that hard,just take it slow and keep track of all the parts and where they go.
WilliamBos
Jul 25, 2015 02:41 PM
toonces
Jul 24, 2015 09:03 AM
trouttracker
Jul 20, 2015 11:54 AM
ghost civic
Jul 19, 2015 10:13 AM
jettman
Jul 6, 2015 12:16 PM
