Newbie question
I recently bought a 1986 lt250r quad. It appears to be smoking blue a little bit. Am I mixing wrong. I mixed at 32 to 1. The Gentlemen that I bought it from said it had aftermarket reeds and a aftermarket exhaust. It is way to fast for me and I would like to get rid of the blue smoke. Also is there a quite muffler that I can buy to make this thing a little quieter ? Thanks in advance Doug
on start up it, is normal for a 2-stroke to smoke, they depend on gas dynamics that change as engine temp changes.
what kind of 2-stroke oil are you using? there are some that are smokeless and after warm-up, there is almost no more smoke... i use a synthetic blend(maxima super-M) at 40:1...once the engine is warm there is almost no more smoke.
jetting could be rich, feeding too much oil& gas into the engine, making it smoke. study up on jetting before trying it or take it to someone who knows how to jet for your area.
You'd have many other problems if it was a bad seal. (Highly unlikely)
It is purely the nature of the beast. (2 strokes smoke, especially with a cold motor)
Jetting could be a little rich also..but if it runs good without blubbering/fouling plugs, I'd be willing to bet you're okay.
Switch oils and see if that helps? I run Amsoil series 2000 synthetic @ 50:1, and have virtually no smoke.
