Winch problem, please help!!!
Old Apr 25, 2002 | 12:53 AM
Cokerg's Avatar
Well, I installed my Warn 2000 onto my Vinson today. I did not hook up the solenoid, because I didn't have the one-way diode to prevent feedback. I want to make sure I installed the thing right. I hooked the negative on with switch to the neg. battery, positive switch to positive battery. I then hooked #1 on switch to #1 on winch and #2 on switch to #2 on winch.
Do I need any type of circuit breaker installed?
Also, as I read the owner's manual I came to "stretching the wire rope". It says to "spool out the entire wire rope length leaving 5 wraps on the drum, then power in the wire rope under a load of 500lb". Well, apparently I didn't have a 500lb load and the cable did not pull back correctly. I hope I didn't damage the cable, I'm going to have to try and pull the cable back off tomorrow and try again. Any ideas as to what I can pull that weighs 500lb w/o my atv moving?
Thanks in advance for the help.
Old Apr 25, 2002 | 01:01 AM
waynaferd's Avatar
Hey, if you don't get many replies, post this over in the Polaris forum, too. There's a bunch of people over that way that know alot about that stuff..............Hook your cable up to a pick-up or something and let the winch pull the quad instead, although you might need some one to help you guide the cable in so it doesn't get all tangled.
Old Apr 26, 2002 | 07:51 AM
monteSS's Avatar
You should hook up a solinoid because under heavy load it will draw more ams thatn the swith can handle. You would run the positive wire through the solinoid and then the switch to the solinoid. It is much like the starter system on fords that have the solinoid on the fire wall instead of how chevy having them on the starter.
Old Apr 26, 2002 | 03:54 PM
MountainCat's Avatar
I would pick up a solenoid at your local Radio Shack! And hook the cable to something like a telephone pole and pull you atv instead of somethign weighing 500 lbs....
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
