I rolled my Z!!!
Old Jun 5, 2002 | 09:48 AM
  #21
chad400ex's Avatar
Well, unless you've got a big dent in the rim, I doubt that you bent the wheel. Those stock aluminum wheels are about as strong as you can get, except for bead locks. Just jack up the rear end of your bike. Take off the tire, start your bike, put it in first, and let it idle. you will be able to tell if the axle is bent, because it will move quite a bit. I had this problem with a Yamaha axle before. I had it "straightened" at a machine shop, but the next ride it bent even worse than the first. Just put an aftermarket axle on, or eventually the wobble in your tire will wear out the bearings in your axle carrier.
Old May 17, 2004 | 03:33 AM
  #22
godleyboy's Avatar
Default I rolled my Z!!!
hey i also live in lake stevens... well everett but more lake stevens, near zion and tom thumb. i'v riden at 5000 but haven't been far in. where does it go? is there a fun place to ride way up in there?
fd24
Jan 16, 2019 08:59 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Albertaboyy
Sep 9, 2015 09:51 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
lancemll88
Sep 6, 2015 03:03 AM
