Zilla vibration ?
Old Jul 4, 2002 | 11:17 PM
Triple's Avatar
350X, I don't know how the 250 is set up but with the 500 there is no need to make sure the piston is at TDC. As long as the three dots are lined up, the vibes will be damped. Aligning the dot on the crankshaft (which of course moves with the piston) will asure that the piston-to-counterbalancer relationship is correct. I would think that the 250 would have been made exactly the same.
Old Jul 5, 2002 | 12:10 AM
Chapy's Avatar
I was able to connect the dots. So hopefully I'll get the motor in sat or sun I'll keep you posted. Thanks for the input! I get anxious to ride.
Old Jul 5, 2002 | 02:38 PM
waynaferd's Avatar
When I rebuilt the top end on my 87 (already had case inserts the summer before the guy I bought it from bought it from another guy[img]i/expressions/face-icon-small-confused.gif[/img] I think I know what I meant) Anyway, it vibrated like hell, and I pulled the rod up to TDC (jug was off being bored) and I lined up the dots, and once I got it all running again it was a lot smoother than before. The dots here lined up but I read on here awhile back to have the piston at TDC, so I think it helped........Latah......
Old Jul 5, 2002 | 03:05 PM
HondaMarshal2's Avatar
Chapy,
Didn't you learn last time at T. City???? I witnessed that spectacle. C'Mon brother the Zilla is Awesome but buy something reliable that you might actually get to ride. Don't bust on the DOG!! He was just repeating what you said when the zilla decided to become extinct AGAIN!!!! Later Bro!
Old Jul 9, 2002 | 11:24 PM
  #15
Chapy's Avatar
Well the beast is almost complete I'm waiting on the bolt that holds the mech. seal in the cooling sys. I'll post next week with the final results.
Old Jul 10, 2002 | 07:44 PM
  #16
Triple's Avatar
Chapy, you have to remember that there are three dots total not just the two on the gears. One of the dots is actually on the crank itself. That means that it rotates in direct correlation with piston position. There is absolutely, positively no way for the relative position of the piston and crank to change. In other words, the dot on the end of the crank in solidly connected to the crank pin and therefore cannot move independantly. The connecting rod is attached to the crank pin (through use of a needle bearing) and the other end of the connnecting rod is attached to the piston (again with a bearing). Anybody that had to even look at the piston position when installing the balancer either had a crank without a dot (perhaps a poorly made aftermarket crank) or they did not know the correct procedure.
Old Jul 10, 2002 | 11:09 PM
  #17
Chapy's Avatar
I have all 3 dots lined up and am awaiting one bolt til blast off. thanks for all the input.
Old Jul 23, 2002 | 01:11 AM
  #18
Chapy's Avatar
To let eveyone know my Zilla is up and running stronger than ever just ask guardog about the a$$ whoopin he received. I broke a ball joint about an hour later but that is fixed now too. Thanks for the input.
Old Jul 23, 2002 | 10:32 AM
  #19
Like I told you before it's an awesome machine but you also have a "WORKORDER ON WHEELS!!!!!"
Old Jul 24, 2002 | 12:39 AM
  #20
Chapy's Avatar
Hey Marshal ask the mutt what happened to him and the C-dale blaze sat. The Zilla might have to stay!
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
Folkzilla
Aug 21, 2015 12:36 PM
coolguy420
Jul 10, 2015 01:17 AM
Dabears1983
Jun 23, 2015 04:59 AM
