lt250r clutch help?
Old Jul 15, 2002 | 11:54 AM
lt250r91's Avatar
Other thing way you got it a part is check to see if the basket has grooves on the fingers.
One question on the clutch plates. Did you soak the new ones in tranny fluid before installing them. If not this could be the problem. If that is the case you need to replace the plates. I would reccomend the factory fiber and metal ones over aftermarket do to the fact they tend to last longer. If you have to replace the basket I would buy the Hinson one instead. I have a 91 that has had the basket replaced 2 times one with a factory one and the last time I put the hinson in it. I race the quad so the clutch gets alot of abuse. The clutch has been replace numerous times. All with aftermarket plates. Next time I do it will have factory ones. Hope this helps. Later
Old Jul 16, 2002 | 03:36 AM
Trixterboy's Avatar
Thx lt I got the calipers now and going to check it out in the morning.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 16, 2002 | 03:36 PM
Trixterboy's Avatar
Oh yeah it's grooved up pretty bad on the right side at the top of the basket. I'm guessing thats the driven side of the basket. Is there any way to repair or is replacement the only option?[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 16, 2002 | 09:18 PM
dual-sporter's Avatar
i've heard that you can file the ridges down, but not far, too much(more than say 0.020&quot and it will cause problems... somtimes thay will break off the 'fingers' of the basket
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Levi Enstad
Sep 26, 2015 08:00 AM
jbrewster94
Sep 23, 2015 04:16 PM
Halffast17
Sep 11, 2015 02:30 PM
