AC Nerf Installation
Old Oct 18, 2002 | 01:00 PM
lateapex's Avatar
Default AC Nerf Installation
It sounds like you encountered the same apparent problem I did. As mentioned earlier, the issue is which engine mount bolt location to use. The nerfs use the forward/upper mount -- then the cross-tubes pass perfectly between the oil lines. I installed the new engine mount bolts and spacers until they were not quite snug; then used a c-clamp to pull the foot-peg plates close to the foot-pegs; then drilled the necessary holes; etc.
AC could make thing a lot easier on buyers, if they would simply add a note telling the buyers which engine-mount bolt to replace.
Old Oct 18, 2002 | 09:42 PM
CallMeBubba's Avatar
Ok, I'm still a little confused. If you are looking at the triangle shaped engine mount it goes on the bottom forward bolt, right?
Old Oct 18, 2002 | 10:52 PM
desertratt45's Avatar
if this forum let you post pix it would be nice. the nerfs bolt to the front lower motor mount bolt. there should be about 1/4 inch clearance between the oil lines. what i suggest is taking a peice of ruber hose and placing it around the oil lines to keep them from rubbing on the nerf tube. as you can see suzuki didnt give me much room to work with.
Old Oct 19, 2002 | 03:04 PM
I think I figured it out. If I mount the front first and dont tighten it down, then mark and drill the holes in the pegs the nerf bars will bend/stretch when I bolt them to the pegs. Does this sound right? I'm about to start drilling.
Old Oct 19, 2002 | 04:37 PM
  #15
thats about as close as a discription as i could give you. it helps if you have a pair of vise grips to hold them in place while drilling.
Old Oct 19, 2002 | 06:18 PM
  #16
kewl, hope it all went on easy minis the directions.
ReconBayou
Oct 31, 2022 05:37 PM
Valder
Nov 28, 2020 07:38 AM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
