interchangable jugs
Old Aug 9, 2002 | 10:12 PM
RxRaptor's Avatar
will a 87 lt250r jug fit on a 86 lt250r trans? if that can be done then witha larger carb i think like a 39mm will that produce enough power to smoke a raptor?
Old Aug 9, 2002 | 11:21 PM
Ronnnnn's Avatar
87 started the powervalve the 85/86 didnt, also to run the bigger carb you need the rest of the engine built to match the extra intake or you will just have a big slug.
Old Aug 10, 2002 | 08:43 PM
RxRaptor's Avatar
thats the reason of putting the 87 jug on the 86 motor because of the powervalve. but will the two work together? what esle is needed to make the motor "wake up"? i know a bigger carb is one item any thing else that would help in power gain?
Old Aug 12, 2002 | 06:55 AM
dual-sporter's Avatar
NO. the actuator or trigger for the powervalve is in the bottom end of the '87-92 motors, but not in the '85-86 motors, also the mounting bolt pattern is different... the motors are very different and the cylinders are incompatible.
Old Aug 12, 2002 | 07:19 PM
RxRaptor's Avatar
dual,
thanks for the info. my buddys father thinks he has a few tricks up he sleeve to improve the power of the 86 lt250. I guess he is full of it.
lightninboy
May 16, 2021 09:52 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
raceware
Jul 30, 2015 06:59 AM
