Question about Ozark measurements
Old Oct 17, 2002 | 07:28 PM
MountaineerTom's Avatar
Default Question about Ozark measurements
Can you measure the distance from the front of the front tire to the back of the rear tire?
I'm looking at getting a trailer and the two I'm looking at have a difference of 16 inches in width, so I want to make sure I get one that I can fit the Ozark on sideways if I need too, between the side rails.
Thanks. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 17, 2002 | 10:32 PM
bsb64's Avatar
Click this link, then click Ozark 250, then click on specifications. The specs are accurate. I used them when building my trailer for a Qrunner 500.
http://www.suzukicycles.com/sr_03/atv/fs_ltf500f.htm
Old Oct 17, 2002 | 11:32 PM
I have those measurements, but I didn't really think about them being the same for the front of the front tire to the rear of the back tire, until I looked at the side photo of the Ozark a little closer. Looks like the frotn bumper is fairly even with the front of the front tire, and the real fenders may hang over slightly more than the back of the rear tires.
I guess I was thinking the bumper and fenders stuck out past the tires more than they actually do.
Thanks.
Old Oct 18, 2002 | 09:56 AM
Dormrat's Avatar
I say get the bigger one. It'll be easier to load and you'll probably be getting another ATV later on down the road which will probably be larger.
Old Oct 20, 2002 | 09:44 PM
Thanks. I probably will get the bigger trailer. The only problem I have is I don't have a lot of space to keep it in. I live on base, on a military installation. If I could get it to my back yard, it would be no problem. I'll probably keep it under my carport, which will mean my truck get to park there any more. [img]i/expressions/face-icon-small-sad.gif[/img] That may lead to another problem as well. My drive way is a pretty steep incline from the street. I have no doubt my truck will back it in ok, but I think the trailer may drag quite a bit trying to get it in and out. I may be able to unload on the street, then unhook it from the truck, and push it up the driveway. A friend has the same one I may get, and it's not very heavy at all. He's going to et e borrow it and "test it out" on my driveway. [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks again for the info.
blueandy88
Sep 7, 2020 03:11 PM
clscott84
Sep 21, 2015 10:16 AM
that1redhead
Sep 8, 2015 11:47 AM
Elkaholic
Sep 6, 2015 02:44 PM
snowolson
Aug 31, 2015 03:51 PM
