need zilla help fast
Old Oct 20, 2002 | 10:02 PM
JeremyKS's Avatar
Default need zilla help fast
well when i slid the side cover off i believe my shaft moved out and caused the spring to come off. At this time i did not realize this and put the side cover back and was trying to go through the gears with my new clutch and i think i may have bent one of the spring ends at this time. Not sure but i am pretty sure that have installed the spring right but due to the bent spring it is not working right. the nylon bushing is the stock one as far as i know and it still seems to be in good condition.
Old Oct 20, 2002 | 10:38 PM
scosho's Avatar
There is an '89 LT 500 for sale where I live. It has a +4 swingarm, pipe, overbore engine with piston, and is otherwise stock, in about 90% condition with some small plastic scratches and seat rips along the metal edges. Can you help me find out what this is worth? I don't want to pay too much for an old quad that has been ridden fast and might be hard to get parts for. Thanks in advance![img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 20, 2002 | 10:43 PM
JeremyKS's Avatar
well just kind of depends on what exaclty is done to the motor. Also what about how many hrs., what tires do you have pics of it. Also what type of swingarm does it have..
Old Oct 20, 2002 | 11:26 PM
scosho's Avatar
Owner claims 20 hr on rebuilt top end, it feels really tight and strong. Just a 1st overbore, new rings and piston. Impossible to tell hours on the machine, original paint with wear at boot contact points. No frame problems, generally sound, chrome 6pak rack, stock bars, no airbox, just a big Uni filter with outerwear. Any round guess would be helpful, thanks for answering so fast.
Old Oct 20, 2002 | 11:45 PM
  #15
OutCast's Avatar
Go to cycletrader.com's web site under there search section. Click Here: Ad Search
In the "keyword" section type LT500 and then click "Begin Search"
This will give you an idea what others are asking for there zilla's.
LT500 won't get you all the search results, so after you've searched
through those, go back and then try LT500R. After that type LT-500
and that should get you most of the zilla's listed on cycletrader.
I hope this helps?
OutCast
88 LT500RJ
Old Oct 21, 2002 | 12:41 AM
  #16
scosho's Avatar
Thanks, I did that while we were corresponding. Looks like they go for $2K to $3500+. That will help when I negotiate for this one.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
