LT250R Power Valve Question Problem.
Old Oct 29, 2002 | 10:49 PM
BomBanshee's Avatar
Default LT250R Power Valve Question Problem.
Could the assembly on the bottom end of the motor be the problem if so can I fix this without splitting the cases and just removing the side cover?
Old Oct 30, 2002 | 12:12 AM
ben's Avatar
ben
there is an o ring on the cover, spray some wd 40 to get it lube,the o ring get kind of dry but you should be able to pull the cover with some pliers,do not just keep turning the spring is very soft so you could damage your spring,there is almost no pressure on the spring ,so if you pull the cover it wont fall,the other thing that you need to check is the position of your exhaust valve when it was installed,that is on your right side(spring) it should snap back when you push it foward,you could also remove the side cover and the control rod to make sure that is connect,your governor dont go inside the case.if you need more help pm me your phone # and i'll call you,
Old Oct 30, 2002 | 08:48 AM
BomBanshee's Avatar
OK thanks one last thing which way should he valve open mine moves up and then snaps back down does this sound correct?
Old Oct 30, 2002 | 07:53 PM
BomBanshee's Avatar
OK i did what you said and it still doesnt work i think im just gonna take it to my dealer and let them fix it, its making me too frustrated.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
