z400 a-arm /shock question?
Old Nov 12, 2002 | 10:05 PM
fast1's Avatar
Default z400 a-arm /shock question?
250lb friend with a bad back needs PLUSH setup for his new z...he wants more travel/soft shocks. whats the hot setup on front arms????? thanks in advance.
yannick
Old Nov 12, 2002 | 11:36 PM
wizeguy's Avatar
Ricky Stator makes the best, most affordable a-arms available (standard travel). They use a 16mm ball joint that's been developed specifically for ATV use. No Volkswagon tie-rod ends like some of the "major" manufacturers. At $525 per set you can not go wrong! Works shocks are nice and come in a variety of styles and options. Triple rates w/reservoirs would be my choice. If you're a high roller go with a Roll Lobo II long travel front end w/ axis shocks! That, my man, is the ULTIMATE! The Stator/Works combo is damn nice for the $$$. Whichever shocks you choose, make sure you have them built and valved for you! Buying them off the shelf will not provide the fine tuning you would want when you're forking over that much coin for a front end! Good luck!
shimanok2
Jan 29, 2016 07:37 PM
NewGuy2481
Oct 6, 2015 05:54 AM
bigred20653
Oct 2, 2015 10:05 AM
bigred20653
Sep 19, 2015 02:11 PM
1ArmBandit
Sep 8, 2015 08:59 PM
