86lt250 shaving head/jug
Old Nov 12, 2002 | 10:55 PM
TomM's Avatar
Default 86lt250 shaving head/jug
I want to raise the compresion on my lt250r. I am considering having the jug shaved to do so. I have not found anyplace that sells high compression 2 stroke pistons and would rather modify the jug anyway so that I could use a standard piston. Has anyone done this? Heard of anyone doing so? Do you know if the coolant passages would still line up if I shave the jug .040"(I havn't had the head off yet)? Any Idea of how much performance I could gain by raising it from 7.2:1 to around 8:1?
Thanks for any info.
Old Nov 13, 2002 | 02:36 AM
fast1's Avatar
i've got an 86 and i took .020 off the head. woke up the midrange quit a bit
Old Nov 13, 2002 | 07:49 AM
lt2502xr's Avatar
when you shaved your head did you have torun hi test pump gas or could you still run 89 octane
Old Nov 15, 2002 | 09:00 AM
sam250's Avatar
Did you lose any reliability or get any other negative effects from shaving the head?
Old Nov 15, 2002 | 01:04 PM
TomM's Avatar
Im gonna shave the head .020" for now and see what happens. It's only 7.2 to 1 compression now so I should be able to run pump fuel if I don't go to far. I might pick up another used head in the future then I will try .030" and .040" and if I go to far I can shave my new head to whatever worked the best before and leave it that way. I will post my results here.
Old Nov 16, 2002 | 02:00 AM
fast1's Avatar
i.m running 91 oct with no prob check your cyl pres after you do 020 you can always take off more
Old Nov 19, 2002 | 04:06 PM
TomM's Avatar
Fast1, Is the head you shaved the standard head? I pulled mine off today, there isn't much clearance for the piston as it is. Also if I take off .020" the ridge around the combustion chamber will be gone completely. I'm not sure I'm going to do so now.
Old Dec 5, 2002 | 07:43 PM
TomM's Avatar
I went ahead and shaved it .020". I got the same result as fast1. I'm happy with my results, particularly the performance increase in 2nd and 3rd gear. Definitely worth 50$s.
Old Dec 6, 2002 | 03:28 AM
fast1's Avatar
good job! you don't need that ridge as far as i can see, there still should be a little ( about .010) if you only take 020 off.
Old Dec 6, 2002 | 03:48 AM
Zilladaddy500's Avatar
What about reshaping the dome after shaving the head to pevent preingnition do to less clearence around the edge of the piston??
