Ozark tail light?
Old Nov 18, 2002 | 10:28 PM
MountaineerTom's Avatar
Default Ozark tail light?
Is it suppose to be light up all the time, even when the headlights are not on? Also, is it suppose to get brighter when the brakes are applied? I noticed tonight that it was one any time the key is on wether the headlights are on or not, and it doesn't get any brighter when the brakes are applied.
Is this correct, or do I have something out of adjustment?
Thanks.
Old Nov 19, 2002 | 01:16 AM
MadMaxJohn's Avatar
The tail light should only be on after you turn your key too the second or last position with your head lights. Brake light should come on anytime you use the brakes when key is on frist position and will be brighter then the running or tail light. sounds like your brake light switch could be jamed or stuck on from mud? so on. hope this helps John P.S. nice pictures.
Old Nov 19, 2002 | 10:14 AM
zookyridr's Avatar
It's out of adjustment down where it fastens to the frame. Mine did the same thing. I re-adjusted it and put a drop or 2 of threadlocker on it. Nice website. My Wife wanted yellow to match my Z400 and all they had left was green. It was the best 2999.00 we've ever spent on a quad. Pro Circuit is making a pipe that sounds awesome and picks the quad up quite a bit. We really like the sound of ours with the pipe. And I'm putting a Web cam in ours since my son is racing it in atv rodeo's. I called Suzuki America and they told me that it uses the same camshaft as the 230 and the old 250 4 strokers.
Old Nov 19, 2002 | 01:05 PM
Thanks all.
Zookyrider, are you talking about where the foot brake attaches to the frame?
Old Nov 19, 2002 | 01:13 PM
Originally posted by: MountaineerTom
Thanks all.
Nevermind, I found where you were talking about. The switch was the part that a little spring hooks too. I moved a little and it sounded "gritty"sounding. Must have been some sand or dirt in there. After doig that, it works like I thought it should in the first place. [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks again for yall's help.
panicmanic
Sep 28, 2015 12:59 PM
clscott84
Sep 21, 2015 10:16 AM
Alex G.
Sep 16, 2015 12:13 PM
that1redhead
Sep 8, 2015 11:47 AM
Tim Shoe
Sep 7, 2015 12:15 PM
