2000 King quad 300 Tire clearance
Old Apr 6, 2000 | 01:45 AM
Du's Avatar
Du
How big can I go with a set of vampires or somthing similar on my ride . I want to go as big as possible to make up for missing ground clearance. Do I need a big wheel kit from ITP or just some rubber.Thank you for any Input. Would love to here what you have on your KQ ANY MOds exspeacily power mods. Pipes jet kits, filters spark plugs cams ANYthing Thanks DUsty Davis
Old Apr 6, 2000 | 09:49 AM
bloodtrail's Avatar
If you go much, if any, bigger on the tires. The King Quad will be a real dog! I used to own a King for 3 years and they are abit underpowered, but with all the gear choices it does the job. I would put a tire on the same size, but just get a tire with decent tread as compared to what the factory dunlops have. Just my opinion!
Old Apr 7, 2000 | 10:07 AM
Machine's Avatar
If you expect that four-wheeler to turn those tires then dream on. You would have to drive around in low range all the time unless you have an engine kit in it.
Old Apr 8, 2000 | 01:00 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
All these posts are right on the money. Best thing you can do for tires in a king quad is to go with a more agressive tread in the stock size. You'll probably find that the knobbier tire will give you a little more ground clearance. I added about 1" when I put on some Titans.
The King just doesn't have the power for oversize tires and even if it did you'd be cutting deep into the 4" or so of suspension travel. Since it's strictly a utility bike, I've never seen any performance mods.
If you want to go fast in a King Quad you've got three choices:
1) Find a really steep hill and go down it.
2) Get somebody on a big Griz. or Sportsman to push you. or
3) Strap your KQ to your trailer, hop on, and have someone drive you down the interstate. LOL
'94 King Quad Titan 489
Old Apr 8, 2000 | 05:21 AM
Bill.Ciliberti's Avatar
I've owned a 87 KQ and a 97 KQ.Do yourself a favor and forget about going any bigger in tire height.The stock tires on the KQ suck.On the 97 KQ,I have 12 wide rears and 8 wide fronts.I have Super Swamper Vampires,WOW,what a differance in traction.Im with these guys,if you want more power,buy a bigger cc quad.===BILL
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
D-Hagz
Jul 4, 2015 02:19 AM
