My Quad on the Alba Website
Dang my quad got on the alba website check it out.
Click here
Its the bottom white one. ive been wanting to get a picture of it on the internet.
Click here
Click here
Click here
thanks, i think all those quads on there look good.
i think its alot better with the reversed wheels, it made it about 2 inches wider on each side and it is alot more stable, i raced a kfx on a circle track and he couldn't make the turns, he had to swing out wide, where mine could hold the track, i think it looks better with the wider front end,
ive got a good picture of the front end but i can't get it to work, i got it one the geocities website but it won't work on here. heres the website if it will work. http://www.geocities.com/nacsz400/Dsc00098.jpg
i took the front wheels and turned them around, you have to pull out the valve stem and turn it around to plug up the hole and the drill a new hole on the other side and mount a new valve stem.then your front end is 4 inches wider and it only cost about 8 bucks, but your brakes can be hit now by a rock or something.
i like the e-series, its just a slip on, i wouldn't mess with the header the stock header is just the same as an aftermarket. i have like 6 disc on there i think, thats how many came with it, you don't have to rejet it, but i did because i put a k&n on there, i love it, it is alot faster now and has alot more bottom end. thats what i was wanting bottom end. were going to go up one more jet on it to try and get more out of it.
heres a good picture of the side, and my messy garage. you can see how far in the front wheels go, and the exhaust.i had to take the c out of central because it wouldn't let me post the address, so add a c in there.
http://www.z400entral.com/tanner.htm
