Gotta ?
Old Dec 25, 2002 | 09:28 PM
Zerorider's Avatar
Default Gotta ?
I have an 86 230S Quadsport. It runs good when it is cold, but does not run near as strong when it warms up. I checked the compression today while it was cold and it topped out at 125. Too low? I am thinking about rebuilding the top end. Does anyone know what the compression should be?
Old Dec 26, 2002 | 06:48 AM
Quadsportman's Avatar
Default Gotta ?
From the Repair Manual I got the following numbers:
Compression:
Standard: 171-228 psi
Limit: 142 psi.
Assuming that you mean 125 psi, then I'd say you have to rebuild. Go out and get yourself a Clymer repair manual for the quadsport, or better yet, search around Ebay and your local shop for the official Suzuki manual. Its a lot better and more detailed than the Clymer one cause its the one the Suzuki dealers actually get so they can service the machines. Its really comprehensive. More expensive, but its worth it.
Good luck with your quadsport.
Oh, and one more tip, use a good title, not "Gotta", so that people will actually read your post and then help you out when you have questions.
Old Dec 26, 2002 | 02:06 PM
Zerorider's Avatar
Default Gotta ?
Thanks for the info and tip.
Old Dec 26, 2002 | 08:46 PM
RacinJason's Avatar
Default Gotta ?
try a valve adjustment before you rip that pig apart...may net you some more ridding time on that piston
BRAAAP
Ahtatu
Sep 28, 2015 12:14 PM
Irishman301
Sep 23, 2015 01:47 PM
Halffast17
Sep 11, 2015 02:30 PM
mattcraig1
Aug 19, 2015 03:48 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
