Changing Spark Plug on my Z-400
Old Jan 7, 2003 | 05:58 PM
Wallie03's Avatar
Default Changing Spark Plug on my Z-400
I'm having problems figuring out how to Remove the spark plug on my Z... anyone have any suggestions for me....???
Old Jan 7, 2003 | 09:59 PM
ngtcrawlr's Avatar
I replaced mine but I already had all the plastic off (i flipped and had to realign the plastic!!!) then removed the gas tank, airbox and snorkel. It was easy but a real pain in the butt to connect the snorkel to the airbox. I don't know if there is enough clearance to replace the spark plug without removing all that stuff. Be sure to check the spark plug gap (my factory plug did not have the correct gap). You will need a ratchet with an extension.
Old Jan 7, 2003 | 10:40 PM
Corpsie's Avatar
There's plenty of room to check the sparkplug without removing anything.
Take the spark plug boot and pull it off and away from the spark plug. Move it off to the side as much as possible. Drop the spark plug removal tool into position and twist with your fingers until it's around the plug's "nut". Use the supplied combo wrench (the 17mm side IIRC) and loosen the spark plug until you can turn it by hand. Keep turning by hand and pull it up and out.
Tada!
Old Jan 8, 2003 | 12:26 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Guess you guys were really thinking of a Cannondale?? Don't you have to disassemble the Cdale to change the plug???
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
