Quadzilla Wiring Question
Old Jan 21, 2003 | 01:51 AM
Thespazardman's Avatar
Default Quadzilla Wiring Question
I'm installing new lights on the Quadzilla (I decided to keep it, afterall), and I have a wiring question for any electrical gurus out there.
Since there are two lighting coils on the Quadzilla, as illustrated here (items No. 2 and 3), is it logical to assume that one is for the low beam, and one is for the high beam? And if that is the case, if I wire the two leads together, will I theoretically improve my lighting scheme?
I'm currently powering two new lights (instead of the old stock setup) via the low beam power lead, and the high beam power lead is capped off. If I splice the low and high beam leads together, will both coils work together to power my lights (they're a bit dim at this point, and I'm looking for an easy fix!)?
HELP!
Thanks.
Old Jan 21, 2003 | 11:48 AM
Jason454's Avatar
Yes those are suppose to be wired together. Lt lights are always dimm till you get the revs up. You can buy a new high output stator from ricky stator for around 130.
Cole Hadden
Jun 15, 2025 09:05 AM
ScopeZ_
Jul 28, 2015 01:44 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
D-Hagz
Jul 4, 2015 02:19 AM
