LT250R Stall Problem
Old Feb 17, 2003 | 02:06 PM
dave1125's Avatar
Default LT250R Stall Problem
I was running my '90 LT250R around the yard yesterday in the snow. All of a sudden it "died" and a puff of smoke came from the front of the motor, it turned out it was radiator fluid. I could not get it started after that. Later in the evening I tried to start it one more time when putting it away and it fired up on the second try. It seemed to run just fine.
At first I thought maybe I had blown a head gasket, but since it started later and seems to be running fine I don't think this is the case. Any ideas? I'm just wondering if it's possible that it just overheated and when the engine cooled down it would then fire. I was riding in 20 degree weather in the snow. Could it be that while sliding around in the snow (couldn't get much speed) that there wasn't sufficient air flow to cool the motor?
I've only had this quad for a few weeks and haven't had a chance to ride it very much. I'm just looking for possible reasons as to why this happened and if there is something I can do to prevent it from happening again.
Any help would be appreciated.
Old Feb 17, 2003 | 04:06 PM
badchad's Avatar
It's possible that snow could have blocked any air from getting to your radiator. Do you see any leaks around the head gasket, and is your fluid level still OK? Check to ensure that your water pump is circulating and drain your oil to see if there is any anti-freeze in it. Hope it's OK!
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
southbayman
Jul 24, 2015 09:30 AM
hondarider1234
Jul 21, 2015 11:53 PM
