LT250R and YZ piston
yes FTZ does do the YZ piston setup, and as with all engine builders there own setup is the best and most powerful. I am hoping to get some feed back from somebody who is running this set up who might be able to give a before and after type response.
What JB said plus it gets rid of the thrust washers if I remember right. THere is a guy on here with this setup from FTZ. I am thinking his login is FTZlt250r. Do a seach for him. I also talked to him about it in one thread.
i guess the question is does it make more power, i will have to do a top end here soon and if i can get more power then i might make the switch.
the guy you are talking about, FTZlt250r, he has a pretty quad, all shiny and stuff, i saw it,
if you could win races with looks the rest of us wouldnt have a chance.
There's just nothing like a bunch of LT junkies!
I don't have a before and after answer for you..... It was FTZ modded when I got it. I need a new top end to have as a back up at the track. You are welcomed to bolt it on when I get it. We could run yours at Tim's, drink iced tea until it cools, bolt on my top end, and run it some more to see if we notice a difference.
Or................ You could finally buy that dyno that you have been dreaming of. [img]i/expressions/face-icon-small-shocked.gif[/img]
sounds like a plan, but do you know if the top ends are interchangable, do they do anything to the rod.
i would buy the chassis dyno that we been dreaming of but then we would know which parts work and dont work,
what fun would that be.
