I need some desperate help!!!!!
Old Mar 23, 2003 | 01:20 AM
RollinDeep's Avatar
Default I need some desperate help!!!!!
I need to know how to time and adjust the valves on a 89 suzuki lt250 sport , I tore this motor down with out the book figureing I would buy on soon but i have been looking and no luck. i was hopeing one of you can help...maybe someone with a manual can give me some help it would be highly appreciated ~Thanks
Old Mar 23, 2003 | 02:25 AM
LT250RSuperstar's Avatar
I have a manual and could tell you, but its like 12:30am so I'll reply as soon as I can.
Later,
Superstar
Old Mar 23, 2003 | 02:35 AM
RollinDeep's Avatar
Thanks you ! Same here im going to bed now
Old Mar 23, 2003 | 12:43 PM
Do you have it assembled or is that what you need along with valve adjustment?
Old Mar 23, 2003 | 11:12 PM
RollinDeep's Avatar
I have it all tore apart and the reason i tore it apart was to time it and adjust the valves because it was running really crappy and it needed it . I know how to assemble it and everything all i need to know is how to time it , and what the valve gap needs to be set to.
Old Mar 24, 2003 | 02:09 AM
Ummmm....Ok,
The intake valve clearance is 0.03-0.08 mm (0.001-0.003 in.)
The exhaust valve clearance is 0.08-0.13 mm (0.003-0.005 in.)
If you need to know how to do this(adjust the valves) just ask, cause I am not totally sure on what your askin for, sorry.
As for the timing the engine...if you got all your timing marks in the right spots and the timing chain has the right tension it should be right on.
Old Mar 24, 2003 | 04:08 PM
RollinDeep's Avatar
Thanks yeah thats what I needed the valve / lifters i forget what my friend told me but this sound right to me. And the reason i ask about the timing is because i look all over and cant seem to find any timing marks and i didnt know if there was a speical way of doing it but this will get me started . Thanks
Old Mar 24, 2003 | 04:10 PM
RollinDeep's Avatar
Sorry to bother u , One more thing. Do you think you can give me the torque settings for the head bolts. My friend keep giving me more info to ask [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 24, 2003 | 09:44 PM
Yeah its no problem. Just ask and I'll tell you what you need or my opinion on what I think on something. I don't know everything but I know some.
The 6mm head nuts are torqued at 5-8ft.-lb.
and the 8mm head nuts at 15-18ft.-lb.
There are marks for the timing and when you align them you must have the piston at TDC (Top Dead Center) on the compression stroke.
Old Mar 24, 2003 | 11:18 PM
RollinDeep's Avatar
Hey thanks alot! Me and my buddy got the engine together today, found all the timing marks and got the valves set. Hopefully it will be ready for this weekend. But while u got the book out can u give me a idea on how to jet it , it keeps fouling plugs hopefully the new timing and valve adjustment but im trying to get everything. Thanks
