Squeaking Brakes
Old Mar 31, 2003 | 08:48 PM
Sunny's Avatar
Default Squeaking Brakes
I'm pretty new to ATV's so I want to get some good feedback before I go and tinker with something and really mess it up. With that being said, my rear brake squeaks like a mouse on crack and my right front brake is starting to squeak a little now too. The rear brake started out squeaking a little and has gotten progressively worse the more I ride. I have been told that this can be fixed simply by flushing them out with a hose (that being between the pads and the rotor)...but this sounds too simple to me. Can somebody out there help me out with this?
Old Apr 1, 2003 | 12:01 AM
ASmurf's Avatar
Any bike with disc brakes will eventually begin to squeak over time. All u really need to do is blast in between the rotors and the pads with a power sprayer. Soap and a tiny hint of WD-40 always helps too. Just take it light with the WD 40 cause u can make ure discs too slick. Plus, check your pads, u never know if they're worn down and its key to get fresh pads to save from grinding on your disc. Don't worry about it though, I just got my Z four days ago and the rear brakes are already singing to me when I ride.
Old Apr 1, 2003 | 01:32 AM
Sunny's Avatar
Thanks for the info. I'll give it a try.
Old Apr 1, 2003 | 07:08 AM
Freakazoid's Avatar
Did you ever burnish your brakes when they were new? This is the process of applying your brakes for about 15 sec. then release and do this a couple of times while you are going ~ 30 MPH. This has helped me in the past when the brakes were making noise. Make sure they are clean before doing this![img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 1, 2003 | 03:21 PM
Sunny's Avatar
No I haven't. I'll give it a whirl though the next time I'm out. Thanks for the tip!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
Canamaniac!
Sep 4, 2015 06:44 PM
