the differences between the lt500r model years
Old Apr 8, 2003 | 05:06 PM
lt500rulesall's Avatar
Default the differences between the lt500r model years
does any one know what the differences are between the lt500r model years.what year has the fastest motor.
Old Apr 8, 2003 | 05:48 PM
TomM's Avatar
87 models had 6 head studs 88 and up had 7, that’s the quickest way to tell. The 87s had higher compression and may have been faster. But I think they compensated for the lower compression in 88 some other ways. I’ve not heard that the 87s were faster.
Old Apr 8, 2003 | 06:37 PM
Duneaddict's Avatar
Modd'ed the '87 will make more power due to the larger intake size. (Another major difference b/w '87 and 88+)
The '87 has a much larger reed cage and intake boot. Other minor changes were front A-arms, graphics, and I'm thinking that's about it...
I think stock HP was about the same thru the years... not enough diff to discuss.
Did I miss anything guy's??
Old Apr 19, 2003 | 09:47 AM
MacZilla's Avatar
Also,there was a gear change to first and fifth. 87 had a shorter first gear so they made it a little taller.I don't remember which way they went on 5th, I just know it was changed. Also, stock rear sprocket size was changed by a tooth,no big deal there. The crankshaft was beefed up in a few questionable areas after 87 also. My 87 is faster out of the hole than my buddies 90, they are pretty much the same after that,and I'm about 25 pounds heavier than him.
1987 LT500R
Old Apr 21, 2003 | 11:05 AM
Duneaddict's Avatar
I wasn't aware of the lower gears, but I do know that 4th gear has a diff. ratio on the newer machinges (88+) that's the diff with the gearing..
Old Apr 21, 2003 | 02:34 PM
ZigZilla's Avatar
The 87 frames are different where the swingarm meets the frame and where the steering stem meets the frame. The steering stems on the 87 also differ from the other years.
Old Apr 23, 2003 | 10:58 AM
Quadzilla1000's Avatar
Your front A-arms are the biggest Diffrence if you are looking at the bike from a distance!
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
Ramman1
Jun 16, 2016 09:07 PM
coolguy420
Jul 10, 2015 01:17 AM
