Z stalls out at high speeds.....
My brothers Z is stock for starters, two weekends in a row out at the ice track his Z acts like it runs out of gas and dies after doing a few laps around the track. All I can tell you is that it had plenty of gas each time and if you let it sit for a few mins it starts back up. Does this sound like valves or electical, or maybe a fuel problem? any help would be great.
Try it with the fuel valve set on PRI. The fuel valve is vacume actuated, and maybe the valve isn't opening completely. A couple of laps would be about right for the float bowl to run dry.
My Z was doing the same thing starting last fall. I pulled the carb off to check for dirt and found nothing, but the thing would run at idle just fine. The next time I went riding it did the same thing, after a few minutes at high rpm, it would run out of fuel. Luckily, my tank was running low so I switched to reserve and it ran fine. The problem is in the fuel valve. I just kept the tank full and left it in reserve and it's ran fine ever since. (scared to price that little valve from Suzuki). Hope that helps....
I bought mine in June '02 and had the problem the first time in September. The same day, I was t-boned by a Blaster and had a new Z400 three-wheeler for almost two months until all the parts arrived from Suzuki. That put me into December before I was riding again and really started to see the problem and as luck would have it, warranty was up. Timing is everything...Hopefully coolintheice has better luck than I..
ps - watch out for those Blasters
