Quadmaster Troubles
Old May 5, 2000 | 12:32 AM
  #21
Danfcarey's Avatar
Demo, how fast will your runner go on a flat dirt road?
Old May 6, 2000 | 01:49 PM
  #22
demo's Avatar
the best i can get from my quadmaster is 56 mph on my quadrunner was 52 but the quadrunner would hit top end a lot quicker.i still like the quadmaster as a better overall trail machine.
Old May 7, 2000 | 02:04 PM
  #23
coyote's Avatar
Have the dealer check out your timing chain.
Joe Wiley
1998 quadrunnerltf500f
Old May 7, 2000 | 09:50 PM
  #24
demo's Avatar
i can get about 56 mph from my quadmaster. c4drm do you get any clutch noise from your belt when going down steep hills?
Old May 8, 2000 | 12:08 AM
  #25
Danfcarey's Avatar
I get clutch or belt chatter when braking on a steep downgrade, but only when using the back brake.
Old May 8, 2000 | 07:28 AM
  #26
c4drm's Avatar
I've never really noticed and clutch or belt noise when going down steeps hills. I often put mine in low range when going down steep hills though. The engine breaking is much stronger in low range and then I don't have to worry about hitting the breaks. The engine breaking is really impressive on this quad.
Old May 8, 2000 | 02:01 PM
  #27
mtngoat's Avatar
This "clutch/belt" noise came up on another post and I never heard an answer. I get it too when on the back brake. Sure sounds like "floating rear brake chatter" which is common on some of my motorcycles. If anyone finds out, please post; just for my peace of mind. Thanks
Old May 9, 2000 | 07:52 PM
  #28
c4drm's Avatar
Mtngoat...any problems with the running out of gas symptoms mentioned in my above post?
Old May 9, 2000 | 08:07 PM
  #29
mtngoat's Avatar
no such problems. over 300 miles logged so far. I did have to re-jet for my altitude (7000'+) and I installed a K&N filter. Otherwise, it's been a great quad.
Old May 9, 2000 | 08:23 PM
  #30
c4drm's Avatar
Why the K&N filter, what does that do for your quad?
