HELP!! I Need A Left Side Case Half For a LT500!
Old May 7, 2003 | 11:22 AM
mtecate4g's Avatar
Default HELP!! I Need A Left Side Case Half For a LT500!
I am rebuilding a LT500 For a buddy of mines uncle. I got the thing in a big pile of parts and when going over everything i found the left side case half is broke of on the front mount by the exhaust valve. It looks like they forgot to take the nut off the stud and pried on it or somthing. I checked all over the internet and to all the parts out fits in the mags and no one has one. Please help as to where i could find one. Thanks!!
Old May 7, 2003 | 12:02 PM
ZigZilla's Avatar
try EASTCOAST ATV they might have one for you.
Old May 7, 2003 | 12:37 PM
Triple's Avatar
If I am not mistaken, you have to buy both halves. You can't just purchase one because it won't match the other exactly. Often, such parts are cast all in one piece and then cut in two which provides two perfectly matched halves (a small amount of extra material is cast into the center section that will be sawed away). Those old Suzuki cases may be formed differently but I doubt it.
Many performance shops can weld your old cases back together (CT racing is an example).
Old May 7, 2003 | 12:41 PM
mtecate4g's Avatar
We have thought about welding it but would prefer a new case. I know the cases should be bought in pairs but the guy doesnt want to spend that kind of cash. I was going to get the case then have the cases matched at a machine shop($25). I have done it before on my old 500 and it worked great. And it beats the cost of 2 case halves. I have called Eastcoast and they dont have one.
Old May 7, 2003 | 02:03 PM
sknaus's Avatar
Well, if you can't find one used, your only option is to buy a new set from Suzuki. They do not sell one side or the other, just as a matched set and it will probably set you back about $600. Get a DirtWheels and look in the back and call around to some of the Suzuki parts places. The good thing is with the new ones you do not have to have the bearing insert mod done. Suzuki fixed that problem awhile ago with the new cases. Good Luck.
Old Mar 1, 2018 | 08:16 AM
Eyeballsdeep's Avatar
you have to get all case halfs, they are line bored and not interchangable from one case to another.
Old Mar 2, 2018 | 02:28 AM
Take a look at the date on this post. I think the owner will have sorted, or/and scrapped it by now.
Old Mar 2, 2018 | 05:46 PM
LT80's Avatar
LT80 Expert
Lol
mtdewmn
Jan 19, 2017 12:13 PM
SDR-II
Sep 29, 2015 01:06 AM
toonces
Jul 28, 2015 01:58 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
