lt250 front end help needed
Old May 2, 2000 | 08:16 PM
EXtreme-'s Avatar
Im looking for info for a buddy that needs much needed help with his quadracer. The bushings or bearings are shot on the a-arms and the front hubs are really sloppy to the point that the rotors wabble too. Are replacement parts available to correct these problems vs buying new a-arms and hubs? Sorry I can't describe this any better accept that the front end as a whole...is sloppy.
Old May 2, 2000 | 11:00 PM
86Qracer's Avatar
Any Suzuki shop (or a lot of places in the mags) can supply you with new bushings (be it a 85 or 86 model) or bearings (87-92 model) and seals for the a-arms. It sounds like it also needs wheel bearings and seals, which are also readily availible. Installation of either is relatively simple, but a repair manual would describe both procedures in detail.
Greg Coats
'87 LT250R
'00 Rancher ES 2X4
Old May 4, 2000 | 10:20 PM
EXtreme-'s Avatar
Any suggestions on replacing the front shocks with factory's or aftermarkets? It's really soft on the landings. The rear was rebuilt by a pro shop but the fronts are orriginal. Thanks for the comeback.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
WilliamBos
Sep 30, 2015 08:08 AM
scaldwellk
Jun 19, 2015 05:08 PM
ragewraps
May 27, 2015 08:07 AM
