Trailboss 330 Foot brake
It's a hydrolic brake.
Polaris is notorious for the rear brake pedeal fading or not working at all. Polaris says the brake is not to be used for braking, use the hand brake. It is designed to be a brake assist.
Makes no sense, but it's in the owners manual.
Best thing you can do, is do a really good brake bleed.
Sometimes, just one good one will take care of it, sometimes you just have to periodically do it.
there is but its very simple first check to be sure youre master cylinder is full take a hose put it on the bleeder nipple on the wheel cylinder run it to a jar to collect the brake fluid pump the brake lever several times to build up pressure then hold the lever down loosen the bleeder brake fuid will be expelled as well as air whitch you'll see as bubbles in line and the lever will bottom then close the bleeder and release the lever repeat the process untill theres no more air remember to check the fluid resivor often dont let it run low or you'll get more air in the system thats about it
oliveiracarlos
09-07-2015 03:39 AM
