Kawasaki Prairie 650 cam shaft vs. Brute Force 750
I have a 2003 Prairie 650 with the top end burned up, and I was wondering if the cam shafts from a 2005 Brute Force 750 will work for me. I know that the rocker arms have the same part numbers, but the cam shafts have different numbers between the two. If they would only differ by value overlap or something simple like that I wouldn't mind. I really just need to know if they will fit in the head.
Thanks for any help. Brandon
