Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Warn winch won't go in or out - HELP
Old Apr 24, 2008 | 01:14 PM
Matlax's Avatar
Default Warn winch won't go in or out - HELP
My buddy and I were out yesterday and I hooked onto his '07 Yamaha factory-installed Warn 2500 lbs winch to get out of a hole (a deep, deep hole) and when he first started pulling his winch was very weak and then it went into freewheel mode. We were messing around with the "wheel" on the right side that selects freewheel or engaged mode but couldn't get it to engage. The motor was running fine, we just couldn't get it to engage.
Anyone seen this? Any ideas before he has to bring it to the dealer? I couldn't find any old posts addressing this issue.
Thanks.
Old Apr 30, 2008 | 10:41 AM
CraZySteve's Avatar
When you rotate that "Wheel" it pushes on an inner rod which disengages the "right side" planetary gears. Sometimes if you do not have tension on the Drum, then you can't re-engage the motor...
I would have about 6 feet of cable out... and turn the "Wheel" to the engage mode. Then I would pull outward on the cable to put tension on the Drum and press the out button to activate the motor... it SHOULD catch... If not... that winch might be done..
Just don't be putting your hand / fingers on the drum when engaging[img]i/expressions/face-icon-small-smile.gif[/img] hence my recommendation to press the Out button....
Old May 1, 2008 | 03:14 AM
eigernthemud's Avatar
yeah i have a gorilla 300 lb xt winch and the same thing happened to two of them actually . On those the selector for freespool and engage is made out of plastic and when they have the least little bit ofdebris in them then the plastic selector gear just shears off . But thats just two stories although it may be worth checking out
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
