Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
LTF 250 no top end power
Old Jun 29, 2008 | 06:36 PM
AdrianXXX's Avatar
Default LTF 250 no top end power
Hi,
my Suzuki Ozark has good midrange but when you get into the top end it falls flat on its face. It revs up high and sounds healthy but there is just no power.
It still gains speed, just not nearly as quickly as it should.
The carb is o.k., I suppose it is not a jetting issue...
Any ideas?
Thanks!
Old Jul 11, 2008 | 02:59 PM
petitecodiac's Avatar
If your jets are clean then I would try to find out what your power curve is.
Old Jul 19, 2008 | 08:57 AM
AdrianXXX's Avatar
Hi,
it behaves like a diesel engine (see below the power curve of a 2.0 D-4D engine). There is quite enough power and torque at lower RPM, but it falls at higher RPM. Maybe I should change the main jet to a bigger one...
What do you think?
Old Jul 23, 2008 | 06:45 PM
These are small engines. You can re-jet the to give you more top end but you will lose at lower speeds. Where do you do most of your wheeling? If you want both bottom end torque and top end you have to have CC's
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
