Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Rear brake problems-HELP
Old Sep 6, 2008 | 10:10 AM
atomlinson's Avatar
Default Rear brake problems-HELP
I'm having some brake trouble with my '03 Grizzly 660. I took it to a mechanic for service, and told them to adjust the rear brakes because they seemed to be soft and not grabbing well. After having the adjustment (which I assume was and adjustment on the cable) I went riding later that day and my rear brakes totally locked up- you could not move the hand or foot brake, and the rear tires were not moving. After a few minutes, the brakes finally released and I was able to limp it back home. I took it back to the mechanic, who checked out my rear brakes and determined that I definitely needed new pads. They put on pads and off I went riding again. A few minutes into the trip and they lock up again! I let it set again for a few minutes, and quickly opened and then closed the drain (I guess?) on the rear caliper, and that released the brakes, and I limped it off the mountain and took it back to the mechanic AGAIN. They had no idea why my brakes kept locking up. I went riding the following day, and after about 5 miles of riding, they lock up AGAIN. I wasn't even using the brakes at all- I was going uphill! The only time I used the rear brake was when going into reverse or high gear. What's up with my brakes? Is it just a coincidence that it happened after the mechanic adjusted them? Why do they keep locking up? A friend of mine said that my brake fluid either got too hot, or maybe I had air in the brake line. Would that have caused this to happen? Any ideas or suggestions would be appreciated.
Old Sep 7, 2008 | 05:32 AM
user493's Avatar
Moto Psycho
Bleed brakes. Add fluid. Cross fingers.
Old Oct 12, 2008 | 08:20 AM
cowdaddy's Avatar
I dont know about the grizzly but on my honda there is a shaft that goes through the hub that sticks if yours is similar take it out sand it lightly with 220 and lube it with lithium grease.. hope this helps
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
timster911
Jul 13, 2015 01:57 PM
