Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
88 yamaha blaster
Old Sep 21, 2008 | 11:16 AM
skidoo3's Avatar
Default 88 yamaha blaster
This blaster has the big bore kit in it which is piston,rings,jets(240 big bore). when sitting sounds like it has a lot of power but when i go to ride it, it really dont. I take off at full throttle and it slowly gets going faster but it is not right. Still running stock plug but going to try a going from a NGK 7 to a 9 today. Carb was totally cleaned when doing this. Not sure what size jet came with kit, but should i try bigger one? I also have to ride with air box cover off because when on it acts like a choke and seems like not getting enough air. Does anyone know where the air/fuel adjustment is supposed to be (how many turns)? Does the switch on top of carb have anything to do with it?
THANKS!!!
Old Nov 21, 2008 | 12:13 PM
shaunsmaxx's Avatar
The switch on top of the carb is the tors unit. Alot of people disconnect them as they do have problems. The blasterforum.com has a write up on how to do it. You may find someone on their who has had the same prob and can help you out.
Shaun
Old Nov 28, 2008 | 12:17 AM
blasterman17's Avatar
yeah you should check the jetting in the carb and see if its right
Sep 17, 2015 03:06 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
