Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2000 Grizzly starting problem. Also having overheating issues
Old Oct 6, 2008 | 10:08 PM
uncleben03's Avatar
Default 2000 Grizzly starting problem. Also having overheating issues
I'm having a problem with my 2000 Grizzly 600. When I turn the key on, the red Oil Light comes on and stays on. When I push the electric start, nothing happens. When I try to use the pull starter, one of the relays on the back of the ATV clicks while I pull the starter. It's one of the 2 white relays (fiche 29U-81950-93-00). Do you think if I replaced one (if I can figure out which one) or both of them I will be good to go?
Another problem I'm having is the Grizzly overheating. I took it in for full service last week and went out riding with it a couple days later. I rode it easy for about 20 minutes then the oil temp light came on and the things started losing power. I shut the atv down, turned the key back on so the fan would be on, and waited until the light went off and tried riding again. Same problem. Fan is working just fine (I think. Sometimes when I turn the quad off then back on to run the fan it won't come on), it was only about 60 degrees out. Radiator is clean front and back, plenty of oil. It did this every once in awhile before the service too, so I don't think anything they did affected it. Any suggestions there?
Old Oct 8, 2008 | 01:12 AM
user493's Avatar
Moto Psycho
Try posting in the Yamaha forum. Good luck.
Old Oct 8, 2008 | 06:32 PM
petitecodiac's Avatar
Jumbofrank didn't help you much. I don't know a thing about your machine, I would make sure that my oil pump is working. That only relates your over heating problem. The other stuff is electrical, maybe a short or a bad connection. When you find it I bet your over heating problem will be solved.
Steven Bandemer
Jun 14, 2015 10:47 AM
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
kylevipond
Apr 21, 2000 08:08 PM
A_TEAM
Aug 19, 1999 12:21 PM
