Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Winch Troubleshooting ?
Old Oct 27, 2008 | 07:46 PM
SwampSnyper's Avatar
Default Winch Troubleshooting ?
SuperWinch
Winch goes out but will not come in. How can I troubleshoot it?
Old Oct 27, 2008 | 07:50 PM
sled05's Avatar
Start by removing wires from winch and contactor. Clean them good, apply dialectic grease, and reattach. Post back if still not working
Old Oct 28, 2008 | 11:36 PM
Solenoid was locked up. Kept working the switch in and out till it freed up. Some terminals were a little corroded so I cleaned them and added grease. Then sprayed them with liquid electrical tape. That should seal them.
Old Nov 6, 2008 | 08:24 PM
swampyjunior's Avatar
If you ride in a bunch of mud/water and your winch is under water/mud because of where it is mounted you may also need to take the motor a part clean it, and grease its gears if you can. My 2500# Warn winch locks up when junk builds up on the gears inside the motor housing. It is supposed to be sealed.
SJ
ReconBayou
Oct 16, 2019 02:24 AM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
