Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
how do i change oil 2003 Warrior
Old Nov 12, 2008 | 08:25 AM
djm1k0's Avatar
Default how do i change oil 2003 Warrior
i was hoping that someone can provide a DIY for changing the oil and filter on a 2003 Warrior. I just got the machine and bought new oil, filter, spark plug, air filter. can you please tell me how to change the oil and the filter so i do it correctly. Also after the intitial change how often am i to change the oil filter ?
thanks !!
Old Nov 12, 2008 | 01:30 PM
ss97's Avatar
Lets Ride!
First off change the oil filter with every oil change.....not before or after.......
The Warrior is annoying to change the oil.......
First take out the huge drain plug - the hole is large and the oil will gush out - careful not to lose the spring on the back side of the drain plug -
Once the oil is done draining, you can put the drain plug back in - which is tricky while keeping that spring packed in - you have to push up and twist on the drain plug -
Remove the oil filter cover (3 bolts) and slide out the filter - take note of how it is installed and put the new on in right away - pour a little fresh oil in the new filter -
These are the basic steps - some will do the filter while the drain plug is still out which is fine also - as long as the steps get done in a proper order - after that you just full the crank case back up with a couple quarts of oil and you should be good to go.....
Old Nov 12, 2008 | 02:50 PM
djm1k0's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ss97
These are the basic steps - some will do the filter while the drain plug is still out which is fine also - as long as the steps get done in a proper order - after that you just full the crank case back up with a couple quarts of oil and you should be good to go.....</end quote></div>
awesome. thank you. do you know about how much OIL it takes ?
Old Nov 18, 2008 | 09:15 AM
cascade quadracer's Avatar
first thing you should do is go buy a clymer book. familiarize yourself with the quad and where everything is at. that way down the road when you need to slip in a new clutch pack ,No Problemo.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
manuelrivera
Aug 8, 2015 04:34 PM
Aug 6, 2015 05:29 PM
