Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Polaris 700 Sportsman EFI fuel pump
Old Apr 10, 2010 | 02:14 PM
ledouxda@hotmail.com's Avatar
The fuel pump problem i had on my '04 700 is fixed. The Airtex E8198 fuel pump cross references over to a Carter P72193 pump here in canada. Still a little better in price at $190. The Airtex FS 111 strainer crosses over to Carter STS209 for under $20 bucks.
Old Jul 20, 2010 | 04:58 PM
alanclos's Avatar
Had same issue with pump...had to go with Bestest BE2044.
so far so good...Orielly for $95
Old Jun 27, 2011 | 08:12 PM
writz97's Avatar
Default fule pump
I can get you a OEM fule pump for $150 pluss shipping....
it is way cheaper then the $500 polaris wants for a new gas tank and it only takes about 5 min to replace after you pull the sending unit out of the tank...
Old Jul 25, 2011 | 12:07 PM
CurtG's Avatar
Default Careful !
I tried this route. I have a 2006 sportsman 500 efi.
I removed the fuel pump assembly from the tank and..
I removed the fuel pump from the assembly..
The pump is quite different from the E8198. Not compatible.
So... I advise you visually match the old and new pumps before being committed to payment.
I bought the tank/pump assembly from Babbit. Ugh.
Old Jul 25, 2011 | 12:50 PM
  #15
CurtG's Avatar
Default X2 seems ok
I also have a 2007 X2. I checked and the fuel pump in this one DOES seem to match the E8198.
But... It looks like a bit of a task to replace the pump into the pump assembly. You will need cinch connectors for the tubes. (I would not use hose clamps on these pressure lines).
green giant
Jul 13, 2017 12:07 PM
atv1972
Jun 18, 2015 09:31 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
CanadianViking
Feb 16, 2001 11:56 AM
