Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Hard starting Timberwolf
Old Jul 4, 2010 | 08:23 AM
xAtvRiderx's Avatar
Default Hard starting Timberwolf
I have a 96 yamaha timberwolf that starts on the first pull with the pull start but is very hard to start with the electric start. This has been a slow thing over time starting. Started good with electric and slowly has been harder.Brand new battery installed..
Old Jul 4, 2010 | 10:44 AM
95wolv's Avatar
2 things, either starter is getting tired, and spinning slower, making it harder to pull a good air/fuel mix in to fire, pull starting spins the motor much faster, so you get a good charge of fuel to start it. 2nd thing, motor may be getting a little worn, lower compression makes it harder to start, still good enough to start with a pull, but getting borderline with starter. Check your compression and see if it is still in spec for your motor, should be 110-125 psi for good starting, any lower than 110, and it may be time for a fresh top end.
Old Jul 25, 2011 | 09:26 PM
xAtvRiderx's Avatar
Default problem fixed
It was the pickup coil located near the stator coil behind the pull starter. problem fixed
Old Jul 26, 2011 | 06:06 AM
95wolv's Avatar
and it only took you a year to fix it.........lol.
chinkapin
Jul 14, 2016 06:58 AM
wildbill59
Jun 22, 2015 09:22 AM
wildbill59
Jun 20, 2015 02:26 PM
wildbill59
Jun 9, 2015 02:28 AM
1000gade
May 27, 2015 12:37 PM
