Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Carburetor Help!
Old Jun 7, 2009 | 05:32 PM
edin351's Avatar
Default Carburetor Help!
Hi everyone,
I know very little about the way an ATV works; I bought one to learn how to work on an engine and an ATV. Today I took apart the carb to install new gaskets and to clean the inside. I put everything back the way I found it but when I hooked everything back up, the gas shot into the air filter instead of the engine. I know that I put it on the right way because the choke was on the same side where "Choke" is labled on the ATV's plastic. I also checked the float to make sure it was okay and I don't see anything wrong with it.
It is a 1996 Honda TRX300EX if that matters at all... Please help!
Thanks,
Eric
Old Jun 7, 2009 | 08:04 PM
Rancher247's Avatar
Have you considered getting a good shop manual?
Old Jun 8, 2009 | 12:02 AM
edin351's Avatar
yeah that was my next step if i didn't get any suggestions on the forum
Old Jul 12, 2009 | 03:28 PM
liketoride's Avatar
you dont have a stuck valve do you?
Old Jul 13, 2009 | 11:06 PM
Beastly 3hundo's Avatar
IDK much about carbs but could the floats be "messed up". I did the same thing with my '05 300ex carb and never had that problem. Or mabe the needle is in wrong. IDK much but I hope I'm helpin you get some ideas.
Old Jul 13, 2009 | 11:11 PM
edin351's Avatar
Yeah thanks, I got it workin though.
Turns out that when i cleaned the jets, it cleared them up and prior to the clean, the pilot needle was set to compensate for the clogged jets so when i cleaned them it screwed up the settings. thanks everyone anyway
Old Jul 28, 2009 | 02:49 PM
runner hard's Avatar
Default carb problems
my 300 artic cat got a hickup lol i am asumming its a carb problem need help on this one what should i buy to rebuild the carb . and can some one tell me the settings on fuel air mixture i only see the one screw. thanks in advance email gordoncollier_45@hotmail.comn
Old Jul 28, 2009 | 02:51 PM
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Aug 1, 2015 04:05 AM
