Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
'87 Mojave water pump problems
Old Jul 13, 2009 | 11:18 PM
Beastly 3hundo's Avatar
Unhappy '87 Mojave water pump problems
Water started dripping out of the wheep hole when I revved it up. So I pulled off the water pump cover and replaced the seals behind the impeller, I put it all back together and now at an idle water SPRAYS out of the wheep hole. I have no clue what is wrong!?! It's mind boggeling. Did I have to go further into the motor by splitting the case?
Old Jul 16, 2009 | 10:41 PM
lt230sman's Avatar
did you replace the whole mechanical seal or just the rubber lip type one?
Old Jul 20, 2009 | 01:25 PM
I replaced the whole mechanical seal. But there was an "oil seal" that went on the other side of the case which I didn't replace. There was no water in the oil so didn't see a reason to replace it.
KimSJoh
14
Jul 18, 2015 07:20 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Mikea1978
Jul 4, 2015 12:37 PM
