Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
"Start Your Engines" fuel system revitalizer
Old Feb 13, 2012 | 11:05 PM
Jerms's Avatar
Default "Start Your Engines" fuel system revitalizer
This stuff sounds too good to be true, but I have read many positive reviews on it after it was highly recommended to me by a local guy who is somewhat of a mechanic. It is a product made by the company who also makes Sta-bil. Have any of you folks used it and how well did it work for you?
My problem is that I have a 1994 Yamaha Kodiak 4x4 which, after friends came for a visit and someone left the key on (killing my battery), ended up sitting for several months with gas in the tank and carburetor. Yeah, I know, you're not supposed to do that but it happened. I was finally able to get it running again but it won't stay running unless it's half-choked, and obviously it's a gas hog the way it is. If I take it out on the gravel road and open it up it wants to bog down as soon as I open the choke all the way. Is this stuff worth the money and effort in a situation like mine? I HATE tearing down carburetors and trying to get them set correctly again, so my hope is that this is good stuff.
Any opinions?
Old Feb 14, 2012 | 08:42 AM
scootergptx's Avatar
Supersock
Hired Gun!
The generator in my trailer hadn't been run in over 2 years, and was not treated at all in that time. We put some of that in the tank with some new gas and got it running.
Then the fuel pump went out.
Old Feb 14, 2012 | 12:05 PM
bartmann's Avatar
Banned
stop being lazy and take the carb off and clean it .... gimmicks dont work...
Old Feb 14, 2012 | 12:53 PM
irinman2424's Avatar
things that are additives such as stabil will work to maintain octane and prevent the fuel from Jelling and gumming up your carb and fuel system if its already gummed up it needs to be taken apart and cleaned real well to get it all out its too late to add something like stabil to it as harm is already done
Old Feb 16, 2012 | 02:46 PM
OPT
Old Feb 18, 2012 | 02:54 AM
95wolv's Avatar
Yup, once you get to the point where the gas has turned to varnish and green gunk, only a good removal and scrub out is going to get that stuff loose. You may find you need to soak the carb over night in a liquid cleaner, or even take it to a shop with an ultrasonic cleaner to get the idle passages clear. I ran into the same thing with my 300ex, it sat in storage almost 2 years, the carb was yellowish green inside, all furry, it took all day to scrub it out and blow out the crud that had settled in the passages, but I finally got carb cleaner to blast out the gunk and got it running again.
Old Mar 21, 2012 | 03:03 PM
thejunkman's Avatar
Should have read my latest article! haha. But yes a complete tear down of the fuel system is the only way to have a reliable performing machine. Never tried the "start your engines" but cannot see how it could work in a situation like yours. Revitilizing "stale" fuel, maybe... but I would not count on it.
Tips for long term storage of your machine - The Junk man
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
sombre
May 8, 2000 12:52 AM
